Cannot make a call
11-04-2024 12:31 PM
I changed my plan since last Friday and I cannot make call since. Every time I tried to call, It says I have reached the limit minute. I don't know what is going on but I am very disappointed to Public mobile. Way too much technical issues 😞 I only join Public Mobile since 2 weeks and I have spent more time with technical support than I actually use it.
Service
11-04-2024 12:36 PM
hi @Chaohao this is a common problem after plan change
Try reboot the phone and try Reset all networks
if same, ask support to help., please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
11-04-2024 12:36 PM - edited 11-04-2024 12:40 PM
@Chaohao Have you tried rebooting the phone ? Can you try your sim card in another phone ? Also can you log into your account and confirm the account is active and not suspended ?
if account is active and reboot didn’t help
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
