Does Public Mobile work with an Apple 11 iphone?
joejays
Just want to make sure before buying one.
8 REPLIES 8
@pankajjoshi
https://www.devicecheck.ca/check-status-device-canada/
Sometimes sellers on marketplace or Kijiji. Sell people phones then turn around and contact their carrier to say they lost the phone or it was stolen so they can get a new phone. Carrier then blacklists the phone. The buyer of the used phone then is stuck with an expensive mp3 player.
pankajjoshi
how to find out if the phone is blacklised ?
Helpershelper
@joejays
Yes your phone would work on the network. If you want to bring your current number to PM you can start the process in store or online, just keep your current account active.
https://www.publicmobile.ca/store-locator
https://www.publicmobile.ca/get-started
Triguy
Yes, it should be compatible.
hairbag1
It'll work for sure. If it's a used phone, make sure it's not blacklisted somewhere.
Jb456
Yes it does.
