Does PM supports eSim?
SAM-A
I bought a phone which supports eSim only. Is there a way I can request eSim from PM?
I was able to find Koodo's process to order eSim but there is nothing on Public Mobile.
Thank you!
hoyjoygang
Great news @SAM-A eSIM is now supported! 🎉
Copied from https://publicmobile.ca/en/on/pick-up-SIM:
Activate with eSIM
Switch to Public Mobile even faster with an eSIM. eSIM enabled devices don’t require a physical SIM card, so you can get set up in minutes with the Public Mobile app
smp99
Hi @SAM-A
Wait a week - not saying they will support eSIM but it looks like an App might be in the works and one of the promo screenshot for the 'new' app makes mention of ESIM
HALIMACS
@SAM-A
guessing it was a new to you iPhone purchased from the USA?
In the US market, these are eSIM only devices.
Great if your service provider supports, but this one does not.
@SAM-A  Unfortunately no esim support with public mobile
hairbag1
@SAM-A
sorry...eSim isn't supported at Public Mobile...yet.
