05-13-2022 02:29 PM
05-15-2022 10:09 AM
@mdepdalwis account with old rewards and good loyalty rewards? some people might want to take over it. Check it out
05-15-2022 09:56 AM
Thanks
05-15-2022 09:55 AM
thanks
05-13-2022 04:35 PM
I second this. Some customers have said they were charged after leaving and had to jump through hoops to deal with that headache
05-13-2022 03:30 PM
@mdepdalwis Make sure you disable Autopay first, then remove the credit card
Yes, it might be extra work, but just be safe
05-13-2022 02:38 PM - edited 05-13-2022 06:14 PM
@mdepdalwis If you're porting out your number, then once your number is transferred your account will close. You should remove your CC from the account while you still have access. Removing the payment card will also mean that your account will suspend and after 90 days of non payment from last payment due date, the account and number will be deactivated.
edited to clarify, that upon removing CC, account will suspend at the next renewal date because of non payment.
