Disabling voicemail
Akagi82
Hi all.  What is the easiest way to disable voicemail?
2 REPLIES 2
Meow
There is no option to disable voicemail.
It used to be a trick to stop Anybody to leave voicemail (extended absence or something like that) but that STOPPED working since PM introduced VoLTE.
I hate this volte screwing up voicemail trick as now every $%&^% can leave vmail and I have to delete them daily.
hi @Akagi82
there is no way to disable voicemail, but you can use Extended absence to help
  • In the main menu, press 3 (manage greetings),
  • then 4 (manage extended absence greeting),
  • then 2 (record a new extended absence greeeting) and record a message that indicates to your caller you are not accepting messages.
  • Then press 4 to turn on extended absence
  • Finally, press 5 to disallow anyone to leave you a message.  Problem solved!
