03-09-2022 09:04 PM
03-09-2022 10:34 PM
@Simon7463 wrote:My account is disabled and i need my account number
@Simon7463 - are you looking to port out of Public Mobile? Just guessing, since you are looking for the account number.
Are you currently in nonpay/suspended status?
After 90 days of suspended/non-payment status, your account will be permanently deactivated, which means you will:
1 - Lose access to your phone number (and Self Serve account), any rewards or Available Funds balance that was in your account at time of suspension, and won’t be able to transfer the phone number to a new provider in the future.
2 - Need a new Public Mobile SIM card if you decide to activate a new Public Mobile account.
You can only port out of Public Mobile to another provider if your account is Active (some exceptions may apply if you are porting to Koodo or Telus).
If you have been active within 90 days, did you try too many failed sign in attempts, which would like you out temporarily.
After waiting over 15 minutes for your next attempt try logging in again, and when you do try opening a tab in incognito mode first.
03-09-2022 09:12 PM - edited 03-09-2022 09:12 PM
Look back for your welcome to public mobile email you received when you activated. The account number will be embedded in the "to" line of that email to you.
It'll be a series of numbers starting with 1 + many zeros...
03-09-2022 09:11 PM
@Simon7463 Account number can be found on My Account but you need to login to find out.
You still have active service with PM? If so, even you forgot the login, you can try to use Forgot Password to try to reset the credentials.
But if you are unable to reset it using Forgot Password, then open ticket with PM Support and they can sort it out:
1. For faster response (2-48 hours), Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
***Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket". Then follow to complete the ticket submission.
2. Or you can Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
**Monitor your Community inbox, envelope on the top right, after ticket is opened. CS Agent will reply and work with you via messaging there
