Tuesday
What is the difference between unlimited Canada-wide talk and unlimited Canada-wide minutes?
@cm1 basically all current plans $25 and above give you unlimited Canada wide talk with unlimited Canada wide minutes.
There is no limit with incoming calls, anywhere in Canada and you can make unlimited outgoing calls to any Canadian numbers
Tuesday - last edited Tuesday
@cm1
Words to describe the same thing. Canada wide talk = Canada wide minutes
As long as you're in Canada, you can call most any Cdn number.
sp
@cm1 - those would be the same things.
@cm1 It’s the same thing just different wording meaning same thing
