Tuesday
- last edited
Tuesday
computergeek541
Have a usa travel plan. Phone has been working , But now no bars. No network connection?
Wednesday
When you come back answer a few questions....
If you purchased your US Roaming add on 10 or more days ago you need to contact customer support to fix a glitch with it not working past 10 days.
Wednesday
nope.. wouldnt connect to t mobile lte...and t mobile 2g hasnt come up as an option. Thanks for all the help yall. I will try again tomorrow!
Tuesday
@leep you don't need to pick T-Mobile 2G, your phone will automatically select 2G network if it is getting voice call and will stay on4G/LTE for text and data
but which roaming addon you got? Voice? Data??
Tuesday - last edited Tuesday
>got t mobile!! TX
@leep so it is up and running???
Tuesday
got t mobile lte...but wouldn't connect.. but no t mobile 2g listed?
Tuesday
got t mobile!! TX!
Tuesday
t mobile does nor come up as an option.
verizin..says forbidden
At and t lte (not forbidden)
First net ...says forbiden
no t mobile?
> t mobile does not even come up as an option?
@leep that explains why yiu are not connecting
are you in another city now compare with when you was able to connect earlier?
Tuesday
in california
Tuesday
Tuesday
@leep yes reboot. power off the phone for a min and power it back up again
if still not work, try this to manually pick T-mobile
Slide your finger downwards starting from the top of the screen.
Press the settings icon.
Press Connections.
Press Mobile networks.
Press Network operators.
manually, press Search networks and wait while your phone searches for networks.if you see T-Mobile, select it
Tuesday
reboot as in power off?
T mobile does not come up as an network option?
incognito mode? but i am pretty sure i still have roaming
Tuesday
@leep you are in the wrong menu, yiu are at Preferred network type page, not network carrier selection page
what exact model phone you have?
Tuesday
t mobile doesnt seem to be an option that comes up? gsm/wcdna/lte or gm/wcdna auto or wcdma only?
Tuesday
btw...did you successfully "buy" the 15 Day US Roaming add-on ? If so, it included talk...right ?
Tuesday
@leep go to Settings, Connection, Mobile Network, make sure Network selection is set to Manual and pick T-Mobile,
Tuesday
make sure you have roaming enabled in settings.
Manually select T-Mobile as preferred network.
Cell service with PM is unreliable in US now.
Tuesday
am techno idiot...how do i do that on an android please
Tuesday
@leep which city and state you are at now? are you in a different city or different area from where you had connection?
try a phone reboot
try to manually connect to T-Mobile networks instead of using automatic
and check My Account using Incognito mode to confirm roaming not expired yet
Tuesday
@leep Need to be connected to TMobile 2G service for voice and depending were you are in the US it can be spotty
