05-25-2022
07:14 PM
05-26-2022
12:49 AM
computergeek541
I no longer wan't my phone carrier to be public mobile, how do I cancel it?
Service
05-25-2022 08:58 PM
HI @junglemonkey-98 if you are not porting out your number and you have the old reward system, you might want to consider to have someone to take over your plan. Because the old rewards system is a lot better, some people are looking to take over old accounts
05-25-2022 08:42 PM
This is key as there have been some glitches where the card still gets charged even after ppl have moved on if autopay and a card is still on (even very rare instances where autopay is deactivated but the card isn't removed) Now you can get a refund for this but it is a hassle to deal with
05-25-2022 07:21 PM
Porting your public mobile number to another provider cancels your account here. Recommended to remove any payment card attached first.
OR, remove the payment card, if one is attached, and then after 90 days of nonpayment your account will automatically close.
If you have enough funds to renew your plan, list your phone into lost/stolen status. 90 days nonpay status all closed and number is gone to you.
05-25-2022 07:20 PM
The best is to port your number over to another carrier and your account will be closed.
Make sure your remove your CC and AutoPay from your account so no further money will pay for your next bill before porting over to another carrier.
05-25-2022 07:19 PM
Stop paying. Remove your credit card. If you have a balance then run it out. Or you can port your number out to close the account.
