10-07-2022 03:17 PM
Phone says ive used 100gb!
On my account it only shows 1054mb however, just wanna make sure im not about to be charged for the massive amount of data next billing period!
Thank-you,
My Account
Payment
10-07-2022 03:28 PM
Oyyeee that was totally it! I was looking at the wifi usage instead! Minor heart attack avoided! Thanks all!
10-07-2022 03:25 PM
100GB?? that is a lot of moeny!! $15 for 1GB!!
Just joking. PM is prepaid, no overage, you have to buy before you use. So, you are safe
Are you on iPhone? iPhone usage won't reset until a manual reset
And maybe you got mixed up with WiFi usage??
10-07-2022 03:21 PM
@MatthewBourdon - is your phone set to the start date of you public mobile plan? If not, do go by what your phone says.
Go by My Account, but ensure you are hitting the circle refresh button to see latest data, or log in through an incognito tab mode.
There is NO overages here. So you will not be over billed for something you do have. 😃 Once you run out data just stops working.
