10-02-2020 12:45 PM - edited 01-05-2022 05:09 PM
i have an iphone5 with the cheapest $15 plan that comes with 250mb of data. Last night I used the amazon music app while connected to the wifi at my workplace. 1 hour later I notice text messages that say I’ve used 100% of my data.
I’m a bit confused as to why data was being used. I use this app at home all the time and never had an issue. Any ideas?
Service
10-02-2020 02:30 PM
@Mmrgreen1 wrote:Texts came from 611. I’ve just turned off cellular data. I didn’t know that was a thing as this is my first smartphone.
thanks guys!
Would you be interested in posting a screenshot of that?
That would be a new thing that all the regulars would like to see. Well...me anyway.
You'll also want to make sure the failover from wifi to cell data isn't on.
10-02-2020 02:19 PM
thanks guys!
10-02-2020 01:27 PM
@Mmrgreen1 wrote:i have an iphone5 with the cheapest $15 plan that comes with 250mb of data. Last night I used the amazon music app while connected to the wifi at my workplace. 1 hour later I notice text messages that say I’ve used 100% of my data.
Are you sure the text came from here? Like from 611? Or did your phone tell you this? It would be news to me that there's a 100% used notification.
10-02-2020 12:52 PM
@Mmrgreen1 only enable data when you plan on using it. otherwise disable it
Disable apps auto update
iTunes & App Stores > Turn Off Use Cellular / Mobile Data
Disable background data
Go to Settings > General > Background App Refresh > Turn it Off entirely or by selective Apps
Disable iCloud sync
Go to Settings > Cellular / Mobile Data > Turn Off iCloud Drive
Disable Wifi Assist
Go to Settings > Cellular / Mobile Data > scroll to bottom > Wi-Fi Assist > turn OFF
Disable data on certain apps
Go to Settings > Cellular > Scroll through and disable applications you don't want to used your Cellular Data
10-02-2020 12:51 PM
Whenever you don't need data...manually turn it off.
10-02-2020 12:48 PM
Do you have wifi assist turned on? It will use data if the wifi signal is weak. Could your phone have been running some updates as well over data?
