Data
Toy
Been PM a little while now. For the first 2 moths or so I had my allocation of data and used it. Now all of a sudden I can't get on the internet with the cellular data although it appears to be available on my account. I have done their recommended test, but still in internet.
chss
You can try resetting APN settings
JC29
Are you using the same phone?  Did you reset your settings by any chance?
popping
Your APN settings may be changed somehow.
Enable your data and restart your phone to get the APN setup automatically.  If restart does not work, your need to manually setup APN settings
https://apn-canada.gishan.net/en/apn/public-mobile
If you are using a LG phone, do a network reset may fix it.
