4 hours ago
4 hours ago
hi @Ok6
there seems to be problem with Mobile data in some area. Try Reboot phone and click Reset network settings
if you need to submit ticket, you can use Chatbot here:
Type the question "Ticket", Then click the following in order: "Account Management" , "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
