12-05-2024 08:28 AM
What happens if I use more data than I pay for in a month. Does it quit, slow down, or do I get charged more.
Plans
12-05-2024 09:07 AM
@Glen7600 wrote:What happens if I use more data than I pay for in a month. Does it quit, slow down, or do I get charged more.
This depends on the specificc plan. While customers on some plans have the data stop working, customers on some other plans get data a slower speed.
12-05-2024 08:33 AM - edited 12-05-2024 08:33 AM
hi @Glen7600
you won't be able to use ore data than assigned. PM is prepaid , once you used up the data, it will stop working.
you have to wait till next cycle or you have to buy data add-on to continue using data
so, you don't have to worry about unexpected high billing
