Sunday
I just started with PM and my data won’t work. It’s been about 7 hours since a signed up.
Sunday
Thanks everyone. I tried some of the replies, but I seemed to get traction when I went to cellular data and turned on “allow cellular data switching.” Hopefully it’s all good now. Thanks, again.
Sunday
hi @IBoo voice is fully functioning?
for data , try Reset Network Settings or try sim on another phone
or tell us what phone do you have
Sunday
make sure you've enabled data in settings ? What make/model is your cellphone ? Have you tried rebooting to see if that helps ?
