10-13-2024 05:23 AM
10-13-2024 11:30 AM
10-13-2024 11:15 AM - edited 10-13-2024 11:17 AM
@MasonG59 Check in your account last i saw there was one 50GB + 10GB 5G unlimited data for $34
so basically 60GB for $34 with throttled data up to 512 Kbps after plan data used up .
10-13-2024 09:59 AM
@MasonG59, something to consider when PM does have unlimited data plans is that they are throttled once you reach a certain point and that throttle speed is very slow, okay for GPS perhaps and maybe some other very light data apps but definitely not good for streaming video or doing multiple things at once like music and gps
10-13-2024 06:08 AM
@MasonG59 Unless you see one as an option when logged in to your account there aren't any being offered at present. Plans offered change periodically so all you can do is keep checking back.
