Data
Help9
Why a new subscriber cannot access data?
Neil11
You will need to contact customer service agent to fix your issue.  Either via the following link:
If you are having a difficult time, then you can private message CSA:
Send a private message to CSA through the following link :
@Help9 physical sim or eSIM??
make sure to remove old sim from previous mobile carrier or disable old esim.  And then go to click Reset Network Settings
Help9
Talk is fine but cannot send/receive texts or access data unless connected to wifi.  I have tried all suggested solutions from chat box and tried rebooting phone. Nothing helps so far.
szu
@Help9
Does talk and text services work?
Which model phone are you using?
May a reboot of your phone.  Or network reset of phone.
