09-17-2023 08:44 PM
when I am making phone calls or sending sms text, does that use any of my data
Service
09-17-2023 09:42 PM
HI @Jojo45
no data needs for regular voice calls and regular sms/mms
With mms, you need to turn on data but it won't actually use your data
But if you call using the app to call, like Whatsapp, FB calling, Skype, Facetime, it consume data
And if you send RCS or iMessage, it uses data as well
So, be careful what you use to make calls and send text
09-17-2023 09:01 PM
@Jojo45 Check your data usage like this
simply try refreshing the page to check data plan / mins / add ons
09-17-2023 08:49 PM
I'd recommend downloading the Public Mobile app to check daily data. My understanding is it updates 2 times a day. You can also go to your account online and look at the usage box and there's a little clockwise arrow, click on that and it will update stats.
09-17-2023 08:46 PM
Thank you. On my account it doesn't show me how much data I am using a day
09-17-2023 08:45 PM - edited 09-17-2023 08:46 PM
Hi @Jojo45
Absolutely not. Calling and Texting are totally different than using data. Although if you do have an iPhone, iMessages will be used as data.
