08-28-2023 07:45 AM
I just renewed my subscription and upgraded to a promotion for 40 gigs at 5G speed...but in the phone Taskbar it is showing 4G. Why?
08-28-2023 09:47 AM
Some phones have a 5G auto setting and only use 5G when the extra speed is necessary/beneficial. My phone switches between LTE and 5G. Have you checked your options, e.g. settings -> cellular -> cellular data options -> voice and data if an iPhone?
08-28-2023 07:55 AM
Get the Speedtest by OKLA app for your phone to verify your speed.
08-28-2023 07:48 AM - edited 08-28-2023 07:50 AM
@JCNFLD Is your phone 5G compatible .are you in a 5G coverage area ? Have you selected your network to 5G ? Also note that even on 4G/LTE you will still get 5G data speeds . With a 5G plan
Adding what phone do you have ? You need to check your phone settings to change the network selection
