Data usage issue(s)
raza1
My data has not been working outside wifi connection, does the signal need to be reset from the tower?
@raza1 - if you do not see your data line under this area of your self serve account: https://selfserve.publicmobile.ca/Overview/, then that normally means you used it all up.
If you do see the data line there, try :
  • restarting your phone
  • toggle into and out of airplane mode
  • remove and reinsert your SIM card
  • CHECK, does your data with if you try your SIM card into another compatible phone?
  • perform a Reset of the device's Network Settings
JK8
@raza1
Your data has to be turned on and check your apn settings:
https://www.publicmobile.ca/en/on/get-help/articles?q=Apn
@raza1
Check to see if your Cellular Data is enable in your setting.
JL9
What model phone do you have?
dust2dust
Has it ever worked with Public? Is this an iOS or Android? Do you see data lines under your my data & add-ons on your account?
