09-14-2022 09:50 PM
09-14-2022 09:54 PM
Or when you're logged in, click on the little spinner refresh icons lower down.
09-14-2022 09:53 PM
Trust me, we have many posts complaining this
With this new site, you likely still reading off the cached version, so the usage you got was not up to date
Try to login My Account using Incognito mode (or InPrivate for Edge, Private for Safari) or try again with a completely different browser like Edge/Firefox/Chrome. You should then see the latest usage from the server
09-14-2022 09:52 PM - edited 09-14-2022 09:53 PM
@joleung -
When looking at the Data Usage Details, make sure you are choosing the DOWNLOAD option and move that into an excel format to have a look. The overview/snapshot that shows for Data in this area is (or was anyhow) just wrong.
Note, data shows up in the usage details section 6-12 hours after it has been used.
To add - go by what is in your overview section in this area below as it is normally most accurate...log in through an incognito tab to avoid cache issues.
