Data usage is not correct...
yeej
My billing cycle starts August 10, 2024.  I checked my data usage from August 10 to August 14th, 2024.  I used a total of about 18mb.  But on the overview page, it shows that I used 113mb.
Anyone else seeing this issue?
Thanks.
10 REPLIES 10
yeej
@axe_grinder
i think it reset after 4 days into my billing cycle.  So that was good.  But this month it's messed up again and now I have no more data available except for what's in my bonus data.
yeej
Thanks again!
@yeej  billing day would not be always on the 17th or 16th.  PM is using 30 days cycle, so billing date will shift up
So, if you are using your phone to track usage, you need to update the cycle start date as well to match
yeej
Thanks for the feedback.  Appears the issue solved itself.  The data usage counter was reset on the 16th of August although my bill shows that my billing cycle starts on the 10th of August.  However, I always remember that my billing cycle was either on the 17th or the 16th.  So I'm not sure if the Start Date on my billing cycles are correct.
axe_grinder
@yeej
What was your previous 30 day cycle's usage? Or your last day's usage? It could be a browser cache issue. Are you out west? The data counter rolls over at midnight eastern on day 30.
yeej
Thank you.  I will try that route.
@yeej
you can open ticket with PM support and discuss with them about the possible discrepancy.
please open ticket with PM support:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Login" and finally click "Click here to submit a ticket ↗
yeej
I am actually using PM's usage data.  I looked at the data usage for the time cycle and it matches what my phone app has...about 20mb.  But overview has 113mb.  I rarely have data usage on so I don't think it's possible that it could be about 90mb off even if there is some daily synching that happens.
I wonder if PM has a direct person or contact I can discuss this with?
Meow
Your phone's usage and what PM reports might not be in sync. Phone might not catch all communication so always refer to PM account. PM updates data usage 2x a day so it is not up to the minute...
eddieO
@yeej the additional is likely from background app updates. If you go into your phone's settings you can control the updates to only occur when connected to WiFi
