01-12-2026 04:00 PM
Hello,
My data is barely being used - as I have confirmed by checking the MB's of usage data - but in the second week of every month I receive messages that I have run out of data - and then I don't have data for the last 2-3 weeks go the month. Can you please help to fix this issue? Thanks.
01-12-2026 06:43 PM
Yes, that's right. The phone and texts work, but I get a text that says I have used all the data. Thanks.
01-12-2026 06:43 PM
I have an iPhone not android phone. Thanks.
01-12-2026 04:47 PM
hi @Karen_H
did you check if you have enabled data limit by mistake? this is a common issue on Android
01-12-2026 04:37 PM - edited 01-12-2026 05:23 PM
So everything else works just fine.
You use data for about a week no problem then it stops working until your next renewal then the pattern repeats?
01-12-2026 04:29 PM
Thank you for your response. MyPM account shows that I have used barely any data, but I still get cut off as if I have used all of the data on my plan.
01-12-2026 04:27 PM
Thank you for your response. I don't have a limit set.
01-12-2026 04:12 PM
Check on you phone's settings that you didn't put on a data limit.
You can check in Network or internet connections or Data.
Or Cellular, Cellaulur Data. If there's a number there either remove it or increase it.
01-12-2026 04:03 PM
Always check PM account to confirm how much data you have left.
And do not leave phone and data ON over night as phone and apps will use it whenever they can.
