08-26-2024
05:30 AM
08-26-2024
07:08 AM
computergeek541
I recently updated my account to more GB a month and am using my internet less and somehow blowing through the new data. I also adding the bonus data and it is almost used up after only a couple days. Does 4g data use up the amounts of gb faster somehow? Or what am I missing that is sucking me dry?
08-26-2024 08:14 AM
@SBee, no 4G should not be consuming data in faster except of course if you are watching lots of videos but that has nothing to do with the speed and more to do with the amount of content you are going through.
You should be able to go into your phones settings, likely under Cellular and see what apps have been recently using data. From there you will at least have an idea of what's going on
