03-10-2023 09:36 AM - edited 03-10-2023 09:37 AM
Received a text from Public Mobile that I was out of data for the remainder of my plan / month
However, when I login to My Account the usage bar is at 3.85GB / 15G
The chatbot suggested creating a new APN (Access Point Name)
And then resetting my data settings
I followed the directions provided, but neither worked.
Looking for other suggestions or advice
03-10-2023 10:55 AM
unneccessary repetition
03-10-2023 09:46 AM
With this new site, you likely still reading off the cached version, so the usage you got was not up to date
An easy way is to click the Spinner on the bottom right of the section to force a refresh.
If you don't see an updated usage still, try to login My Account using Incognito mode (or InPrivate for Edge, Private for Safari) or try again with a completely different browser like Edge/Firefox/Chrome or try on another device. You should then see the latest info from the server.
03-10-2023 09:46 AM
HI @madolyn Likely the text is correct and the My Account page you saw was just cached, not live data
Please use Incognito/Private/Secret mode to login to My Account and check your usage there
03-10-2023 09:42 AM - edited 03-10-2023 09:44 AM
@madolyn - when logged into your My Account click the little circle refresh button below. This should update your account to the latest info.
Or, log into your account through a tab in incognito mode, this helps too.
Calling 611 from your phone, you can also check your remaining balance.
If you have more data left then the 100% message you received, you can ignore the text. Sometimes, in the past, Public has sent out erroneous texts.
EDIT, but you said 'data stopped working'. Well then, check on your phone if you have a data limiter set on it. If you do remove it or edit it.
OR, you have simply run out of data of course.
03-10-2023 09:40 AM
I would suggest below to be 100% sure what is going on with your data:
Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
