Data rollover
Options
09-07-2016 01:16 PM - edited 01-04-2022 03:12 PM
I just joined and was wondering if the your unused data carries over as long as you are with PB?
e.g at the end of the 3 months term you have 2 gb unused does it over into the renewal?
Labels:
Service
1 REPLY 1
Options
09-07-2016 01:22 PM
Hi. No, Data Plan doesn't, ONLY Add-On Data
