08-12-2022 11:16 AM
I purchased the $25 dollar plan and was thinking of switching to the $40 plan just for the extra data should I do that or purchase the add-ons instead? Thanks!
08-12-2022 03:45 PM
depends how much data you useing for 30 day,
check it out and if you cover with plan $25 1GB, then good,
or to buy it add-ons price is to expensive, but if needed for Emergency then buy it.
or think to change plan to
Data at 3G speed for $35.00
3 GB
unlimited / Canada-wide minutes
unlimited / international Text and Picture Messaging
or
Data at 4G speed for $41.25 plus tax
4 GB
08-12-2022 11:25 AM
If you switch NOW, you will not get Plan's price difference nor refund. So you might pay for 2 plans in short period of time. If you are close to renewal then it makes sense to switch NOW otherwise schedule Plan change for next renewal.
$25 Plan has 1GB. + 1GB Add-on = $40
$40 Plan has 3GB. Difference 1GB.
08-12-2022 11:22 AM
If you're thinking you'll be using more data every month...I suggest you change plan to $40. The cost for data add-on is ...exorbitant.
