Data purchase
Zeenie
I need to purchase some data
Meow
Go to
and purchase whatever you need.
Sansan
Ok, what's the error?
It's easy. When you sign into your account, click on My Rewards. It will take you to the Rewards portal.
Click in the catalog and find the add-on you need. It will tell you if you have enough points. Click to confirm.
Or if your not using points, shop add-on and use the registrated card in file to pay for it.
porcupine
Go to add on and purchase data
