Data on 25 dollar plan always zero
sp2017
Why don't I have data 500 mb plus bonus 500 mb autopay when I'm on 25 dollar plan?
It always says zero balance. I have this problem since I purchased this plan.
19 REPLIES 19
picture has been removed from the post, but @sp2017  will still need to delete if from the community profile
@sp2017
It looks like you are on this plan that does not include any plan data. If you stay on it and purchase add ons or you get free data add on gifts they will be full speed 4G LTE. All current plans are 4G LTE data throttled to 3mbps. So consider carefully how important data speed is for you if you schedule a change plan on next renewal. Once you switch you cannot get this plan or full speed 4G LTE speed back.
@sp2017
Remove your last screenshot from your profile and edit it out of your post. Your phone number is showing. Is this your plan from activation? How long ago did you activate? Do you have autopay?
JK8
@sp2017
Before you consider a plan change ask the CSA if this grandfathered provincial plan included data at 4G LTE speeds.
@sp2017
you have to Contact Customer Support Agent by  ,
and see how you contact them at my original post instructions..
LeePublic
@sp2017 The problem seems to be your plan was a grandfathered plan that didn't include any data. PM hasn't offered provincial plans for a long time. (Other than that unpopular move about 4-6 months ago) You have to log in to your account and select the new $25 plan and set it to renew on the next date unless you want the data now, then renew now.
JK8
@sp2017
Change your plan on the next renewal date. You have an old provincial plan. You can get the unlimited Canada wide calling for the same price.
For now contact a CSA regarding the missing data.
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get started.
  • Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work.
Hours of operation:
You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
  • Monday to Sunday: 6 AM to 10 PM EST
Keep an eye on the envelope icon in the top right hand corner for a reply from the CSA.
sp2017
Here's my plan 25 dollar
JK8
@sp2017
Log into self service with this link. What does it say under My Data & Add-Ons:
https://selfserve.publicmobile.ca
sp2017
sp2017
It shows this
Yummy
 There is no point of discussing your data usage and trying to assist unless you provide screenshot of your PM account where we can see how much you are allotted and how much you really used of your data.
t_p
@sp2017
There is a chance your SIM has not been provisioned properly.
You can open a ticket with CS via:
JK8
@sp2017
To get your phone to access the data make sure your mobile data setting is on and your APN settings are correct:
https://www.publicmobile.ca/en/bc/get-help/articles?q=Apn
If you can use wifi somewhere right now check under My Data & Add-Ons in self service and tell us what the data line says.
@sp2017
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
and do again Rebooting your phone,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
and you can try to reset network settings on an IPhone
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit  Here link,
click Here link,
How to reset network settings on an Android device
  1. Open the Settings app on your Android.
  2. Scroll to and tap either "General management" or "System," depending on what device you have.
  3. Tap either "Reset" or "Reset options."
  4. Tap the words "Reset network settings."
   or visit  Here link,
and go Changing APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
sp2017
  • When I try to access the internet. It always take me to a page that says zero balance.
JK8
@sp2017
When you look under self service under My Data & Add-Ons is there a line of data displayed there?
@sp2017
Explain your issue to Contact Customer Support Agent by  ,
they can solve your issue, they are nice Service Team they will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent,
  • or you can send a private message to Customer Support Agent by CS_Agent, by Click Here link,
  • You’ll need to be logged in to your Community account for the link to work.
  • your account number,
  • your phone number,
  • your account 4 digit pin,
  • your Email address,
  • Customer Support Agent by CS_Agent, will Response to your inbox by private message
  • During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
         Good Luck...
t_p
@sp2017
When did you activate your plan?
Any chance you've used up all the data without realizing it?
Check your Data usage and post a screenshot if possible.
