Data not working
FrankThiessen
Please help me get my data working on my phone.
FrankThiessen
Hello Friend.  With my wifi off, my data is now working, Thank you for your help
FrankThiessen
Hello Friend. My phone is a Samsung Galaxy A5, model #
sm-A520W
I will reset the network. Please be patient with me. I have never done this before
HI @FrankThiessen
Give us more information, what phone is yours?
the first thing to do.  Click Reset all Network and it will hopefully update the correct APN
If not, then you will have to update the APN settings manually
  • Name: Public Mobile
  • APN: sp.mb.com
  • Username: (Not set – Leave it blank)
  • Password: (Not set – Leave it blank)
  • Proxy: (leave it blank – not set )
  • Port: (Leave it blank – not set)
  • Server: (leave it blank )
  • MMSC: http://aliasredirect.net/proxy/mb/mmsc
  • MMS Proxy: 74.49.0.18
  • MMS Port: 80
  • MCC: 302
  • MNC:220
  • Authentication type: (none)
  • APN type: (default,supl, mms)
  • APN protocol: (IPv4)
  • Bearer: (Unspecified)
  • Mobile virtual network operator: (none )
dust2dust
Log in to your and click on any little spinner refresh icons you see or use private mode to try to see updated information.
