05-12-2022 11:15 AM
Hi all, recently my data has not been working on my account. It asks me to sign into a network but then says "system network error". I tried checking my plan on the website to see if anything had changed but every time I click on that it logs me out. I did a system reset with the help of "Simon" but nothing. I think I have 5GB included in my monthly plan (again I cant verify that as it keeps logging me out) and I rarely go over that (currently have used 23mb). Any ideas what I can do?
05-12-2022 11:58 AM
Is your usage based on PM self serve account or a phone counter, there may be a discrepancy there.
05-12-2022 11:47 AM
When was your renewal?
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here ....for additional member supplied info.
05-12-2022 11:32 AM
Problem with logins usually get resolved using different browser. I can confirm logging in works fine...
05-12-2022 11:25 AM
That error typically means you have used up your Data add-on. You need to login to selfserve and check that you have or don't have any data add-ons. When used up they dissapear.
What do you mean it keeps logging you out? Try from a different device?
05-12-2022 11:24 AM - edited 10-02-2022 12:11 AM
hi @Monicadowson what kind of system reset did you do? Network reset? Factory reset?
did you check your APN setting?
or put your PM SIM in another phone to test if you have a spare phone
