Data not working
Send2ssj
Data has not been working for months just found out any ideas how to fix issue .
Triguy
Log into your account to check if you have data showing.  Make sure you have the correct APN settings.
Check your APN settings.
Here’s how to set up data in 3 steps:
1) Tap:
  • Settings
  • More
  • Access Point Names
  • New APN Settings
2) Input this info:
3) Leave all the other fields blank. Hit save.
Try rebooting your phone.
@ ummm? If you just found out, how do you know if has not been working for months?
You could try:
  • reboot phone
  • toggle to airplane mode for a few minutes, then back to regular mode.
  • try SIM in another compatible Public Mobile device
  • If trying in another phone works, reset network settings on device that it does not work on.
Send2ssj
let me check thx for the quick reply
Staliger
@Send2ssj Go to self-service profile and check how many data do you have there. Di you have working data previously? Did you change your phone?
 @Send2ssj : Has mobile data ever worked here? Do you see the data line item under My Data & Add-ons?
