Data not working
12-22-2018 04:10 PM - edited 01-05-2022 02:52 AM
I have recently changed my mom's phone service provider to Public Mobile, and got the $50 30-days plan. But we can't get the data to work on her phone (at all). We have previously been able to use data on her phone, and also it worked when I switch the SIM card to my phone. What should I do? It is really a waste of $50..
12-30-2018 05:22 PM - edited 12-30-2018 05:23 PM
@CW123 wrote:I paid $20 1G data add on on dec 28, 2018 after one day the data stopped working i only used 97mb. I have restart the phone but it is still not working what is worng with the data. my phone is working its just the data that is not working.
20$ for 1 gb..thats the data roaming addon ..?
12-30-2018 05:16 PM
12-24-2018 01:30 AM
@jlyg as @Anonymous and @ShawnC13 noted, we need to know what phone you're trying to use. Some models (such as many Asus phones) need a manual APN configuration. Older iPhones (I believe 4S and older) need a special 1-time configuration procedure. And many LG models require a network reset, and if that doesn't work, a factory reset, in order to get data working after changing providers. We can try to help once you provide more details.
12-22-2018 04:54 PM
@jlyg wrote:I have recently changed my mom's phone service provider to Public Mobile, and got the $50 30-days plan. But we can't get the data to work on her phone (at all). We have previously been able to use data on her phone, and also it worked when I switch the SIM card to my phone. What should I do? It is really a waste of $50..
What type of phone does she have? If an LG they are known to have a network reset or even a factory reset done on them when going to another provider. Also have you checked and verified the APN settings on her phone.
Here is a great site to setup your APN and instructions on how to do it. Find the APN Settings for Public Mobile here!
12-22-2018 04:31 PM
@jlyg, what phone does she have? Is it compatible with Public Mobile data network? If so, have you checked the APN settings?
