07-03-2015 12:02 PM - edited 01-04-2022 12:40 PM
03-10-2020 10:58 AM
I purchased an add-on, however last night I changed my phone number and when I look to see if there is any data left it doesn't show any activity for this new phone number. Did I lose my add-on because I switched numbers?
03-10-2020 03:52 AM
ok... i just sent a ticket.... 😊... thank u for the help... will comeback once its all fix
03-09-2020 08:59 PM
@deonxx76 wrote:Its now monday night EST.... Still no data... Tried using the sim in other phone.. No luck.... Im on the $40 plan... 5gig data... Correct APN settings after resetting network.... Rebooted several times... Re inserted sim several times and the airplane mode as well
If it is not working in another phone, it is likely a PM service issue. Maybe account provision problem.
You should contact moderator to check your account.
Click on the question mark on the right lower corner of website to start ticketing process to contact moderator. Type: Contact moderator. Follow the prompts to submit ticket.
03-09-2020 08:55 PM
03-08-2020 02:39 PM
ok i will try and put the Sim on the diff phone... and also will wait for the system to fix thier bugs.. thank u
03-08-2020 02:30 PM
03-08-2020 02:27 PM
i did all 1 to 3 that u mentioned... i own a Huawei p30 lite..
03-08-2020 02:26 PM
03-08-2020 02:16 PM
im a rerurning customer... APN are correct.. but no luck with data connection... i see the LTE and or 4G connection but no internet
03-08-2020 02:14 PM
i recently returned from a 2 month vaca and reregistered using the plan i used before leaving the country... my calls and text works but my data does not.... my APN are all correct down to the last point.. but still no luck connecting to the internet and send MMS using my data plan... pls HELP
08-26-2019 10:04 AM
Other people have had success putting a Freedom SIM in, which seemed to have allowed them to add a new APN, fill in Public Mobile settings, reboot. Put Public Mobile SIM in.
Found the post https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/Android-8-1-APN-settings/m-p/289974/h... in the big Android 8.1 APN thread: https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/Android-8-1-APN-settings/td-p/241715
08-26-2019 09:59 AM - edited 08-26-2019 10:00 AM
@MarioD wrote:Once again I find myself unable to connect to mobile data with ASUS Zenfone 4 Max on Android 8.1 following a system update. However I no longer have the ability to modify the APN to the correct value. But why should I have to modify the APN? The APN value should be correct when I select Public Mobile network from my list of network! I've seen previous posts with ABD modifications and Public Mobile blaming the phone manufacturer but why couldn't Public Mobile ensure the correct APN is associated with their network!
What did you do before to get 8.1 working?
Some other SIM's will allow editing/adding APN's. Like Freedom, Roam, Speakout. Somebody wrote an app that you can install that will allow it.
Agreed that's it's a hassle but Public Mobile aren't alone with this 8.1 problem.
08-26-2019 09:56 AM
05-04-2019 11:09 PM
Missing last step: Restart your phone.
I followed the steps and it didn't work, but I then restarted my phone and data started working!
Add that step and see if it resolves it for you.
Cheers.
02-22-2019 12:06 PM
@Anonymous wrote:
@SkimGuy wrote:Did you enable mobile data in the settings and register your account on the network?
SkimGuy
Four posts...who are you replying? For a post to make sense in the flow of the thread it's helpful to either use the black Quote button or use the @ username tag like I did here or even just the username.
fyi
I was talking to @Raymondtsang555, will quote in the future. Thanks
02-22-2019 12:04 PM - edited 02-22-2019 12:05 PM
SkimGuy
fyi
02-22-2019 12:01 PM
02-22-2019 01:58 AM
@Raymondtsang555 wrote:Hi I'm also having difficulties with my data. Help please! I'm a new user to PM. Created my New VPN per instructions and it's not working.
Can you post some screenshots/pictures of your APN settings? This would help for others to try to see if there are any errors.
Some of the time, customers need to change and Android data setting to APN Type default,supl,mms
02-22-2019 01:34 AM
09-30-2017 09:58 AM
The solution worked for me.
thank you.
06-20-2016 02:41 PM
@pepper haha 😉
You're welcome!
Shazia
06-20-2016 02:22 PM
@Shazia_K Thank you so much for the prompt solution 🙂
My apologies for the NOT so prompt reply. hehe.
06-17-2016 05:20 PM
I had sent you a private message earlier, i'm leaving for the weekend, just checking to see if you had the chance to view my message?
Thanks,
Shazia
06-17-2016 12:09 PM
thank you for getting back 🙂
Have you tried rebooting the phone? if yes, please send me a private message along your Public Mobile phone number.
Thanks,
Shazia
06-17-2016 12:07 PM
Hello @Shazia_K
I apologise for the confusion, I have already added the 'add-on' data and the payment has gone through as well. However, my phone doesnt seem to recognise that I have added more data.
I have a Nexus 4.
waiting for your help. Thanks in advance! 🙂
06-17-2016 11:04 AM
Hello @pepper,
I'm sorry to hear about this,
Are you trying to say that you are unable to add a data add-on to your account from the self-serve?
Please explain, in order to better assist you.
Thanks,
Shazia
06-17-2016 11:00 AM
Hello @Cyber,
I have a 90 day 1 GB data plan, which finished, so I got an Add on. But that doesnt seem to work. I followed your instructions but even now, its saying "Sign-in to network".
Help Please !
06-13-2016 03:34 PM
Welcome to Public Mobile and the community, @angieet93!
06-13-2016 12:46 PM
Thank you so much! This worked perfectly for me 🙂
05-29-2016 04:36 PM
Hi @MarchForward, welcome to the Public Mobile community. We need a bit more information to try to help:
1) Are you new to PM and the data has not yet worked at all? or you're an existing customer that previously had working data? If you previously had working data, have you recently renewed and/or done a plan change?
2) What make and model of phone are you using? If it's working okay for phone calls and texts but not for data, then it sounds like it's probably an APN issue. Have you gone through the steps listed earlier in this thread to verify your APN set up?
