05-16-2024 06:38 PM
Hello, I became a subscriber last week and now my mobile data is not working. Can someone help? Thanks
05-16-2024 07:31 PM
Thank you for your reply. I has tried resetting the networks and it still wouldn't work. S22, samsung
05-16-2024 07:30 PM
Restarting seems to have helped. Thank you for your reply
05-16-2024 07:28 PM
No the limiter was set at 2GB, a lot lower than my available data. Thank you for your reply
05-16-2024 06:47 PM
Any chance you have used uo all of your plan data?
Do you have your data limiter set on your device? ( Default is 5gb usually?)
05-16-2024 06:41 PM
@BlueStarFire wrote:Hello, I became a subscriber last week and now my mobile data is not working. Can someone help?
Earlier, I also noticed data not working. Websites would not load and I could not use anything that reqauired an internet connection. After a few minutes, the mobile data connection did start working again. If you haven't already done this, please also restart your device.
05-16-2024 06:40 PM - edited 05-16-2024 06:41 PM
what brand and model your phone is?
Try to Reset All Networks or Reset Network Settings first and see if it helps
And if iPhone, make sure iOS is updated and you also download the latest Carrier Profile
05-16-2024 06:40 PM
can we assume Data is enabled in settings ? What make/model is your cell ?
