07-27-2023 10:43 AM
Hi PM specialist,
It shows I still have Data left on my account but it's not working. I can't open any web pages or browse anything. Could you help look into it?
Thank you.
Guiying
07-27-2023 01:29 PM
I am in Toronto. My family all use PM, and theirs working fine.
Really not sure why I can't use the data. Does it solve the problem if I switch to higher monthly plan?
07-27-2023 10:58 AM
Hey I have the same issues too. I just auto-renewed my subscription plan today, I have 20GB left. No data is going through my phone.
07-27-2023 10:52 AM
Yes, I am using Incognito mode. The add-on promotion still has 45% left. And I am using iphone. Thank you..
07-27-2023 10:52 AM
generally, where are you located ? I see there's several large network outages in different parts of the country...perhaps that's the issue.
07-27-2023 10:48 AM
Thank you for the quick reply.
It shows I still have 45% data left on the promotion 4G. Is it not useable? How to use it please?
07-27-2023 10:46 AM
To avoid reading cached info, please check My Account again using Incognito mode , confirm you sitll have data left
Also, if you are using Android, make sure you disable data limiter on your device.
07-27-2023 10:45 AM
