Data not working with new phone and new plan.
Y2kayo
Umidigi g1 max,
I can't for the life of me get the data to work no matter what apn settings I use.
Calling and texting is fine.
Someone help
2 REPLIES 2
@Y2kayo Umidigi phone , yes, it is a bit more work for this brand of the phone.  And it is likely an APN problem
Easy trick is to first click Reset all Networks.
if it does not work, please go to the APN settings page to either update your current one or make a new one following this:
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
         or    default,mms,agps,supl,fota,hipri
           (might need to include dun for hotspot)
APN protocol: IPv4
APN roaming protocol: IPv4
APN enable/disable: APN enabled
                or  Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
HI @Y2kayo  what phone do you have? could be a phone compatibility  problem
first , Reset all networks
and you can also try your sim card in another phone
