2 weeks ago
Anyone else have their data stop working after upgrading plans? Last month I upgraded to a different 4G plan with a higher data cap. The new plan kicked in and now my data won't work. My phone is also only showing a 3G network connection when before I had LTE. I doubled checked and I am on a 4G plan, not sure why it has stopped working just because I got a higher data cap.
2 weeks ago
2 weeks ago
when upgrading or downgrading plans make sure to manually add funds to the account before the renewal takes place. there are times the account will not provision correctly if using autopay to handle the upgrade/downgrade
2 weeks ago
@zamba if you've rebooted device probably best to contact a CS agent for them to check your account.
Changing plan shouldn't disable your data.
You can contact an agent using the chatbot. Type "agent" and click contact us to go through the wizard.
If for some reason they don't respond to the ticket, you can try to send an email directly to the CS Agent here.
Here is a help article about how to contact the CS Agent.
2 weeks ago
Unfortunately that was the first thing I tried.
2 weeks ago
restart the phone
