11-08-2016 03:46 PM - edited 01-04-2022 06:08 PM
I have an Axon 7 on the new 4gb/mo plan. I signed up last week.
Data was working fine this morning, then this afternoon it stopped working with no warning.
I can still call out and call in. Phone info says its on LTE/WCDMA/GSM auto (prl). If I force it to LTE only it won't get any signal. I am in the middle of trying a full wipe but I am not hopeful.
I have deleted and reset the APN multiple times and it is not helping.
Any advice?
11-09-2016 11:03 AM
Yup, definitely odd. I have been messing with the software a bit, but it is strange a reset solved it.
11-09-2016 11:01 AM
Strange behavior...
I know that the software of the AXON has many bugs. Maybe one of these?
11-09-2016 08:00 AM
11-08-2016 03:59 PM
hi..
i would not use the force LTE option.... if signal gets weak you will also loose your phone service as well .... at least that was the last word here on the board ( PM does not support VOLTE...i think its short for voice LTE )
