06-23-2021 06:48 PM - edited 01-06-2022 02:36 AM
Hello! I joined Public this morning, and the service is great! Just as good as Telus. On the other hand, I quickly noticed my data wasn't working... and trying to figure it out since. Any ideas? Thank you in advance!
4 weeks ago
i Joined public mobile this morning as-well, (i have iPhone 14) calling/texting was working, data was not, i tried all the troubleshooting, come to realize i needed to take out my old sim card inside the phone. works great now! hope this helps other iPhone users with this issue! 🙂
06-24-2021 03:54 PM
Solved!
for iPhone 6s:
Settings, General, Reset Network Settings. 👍
Just remember to re enter your wifi password, and that’s all there is to it!
06-23-2021 09:26 PM
@brendang do you have an iPhone? if so, you might want to connect to a computer, use iTune and update the phone and download latest carrier profile.
06-23-2021 07:28 PM
If you are using an Android phone then make sure your have these APN settings.
06-23-2021 07:04 PM
@brendang wrote:Hello! I joined Public this morning, and the service is great! Just as good as Telus. On the other hand, I quickly noticed my data wasn't working... and trying to figure it out since. Any ideas? Thank you in advance!
Hello,
If rebooting or toggling into and out of airplane mode is not working for you, try a RESET of your Network settings.
Also, what model phone do you have?
06-23-2021 06:50 PM
@brendang : Most likely APN settings. If this is an Android phone then you can find APN settings or post screenshots of what you have. If it's an iphone then you likely need to connect via USB to itunes and look for any updates.
06-23-2021 06:50 PM - edited 06-24-2021 05:40 PM
do one thing take your SIM card out and waiting for a minute and put it back and do rebooting your phone - This one is quick and simple. Make sure your phone is off before removing and reinserting its SIM card.
Remove your phone’s battery - Some phones have removable batteries. Sometimes removing and reinserting the battery can fix certain issues. Just make sure your phone is off before you do this.
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
Ensure you have the correct APN settings by visiting HERE.
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
visit HERE
Changing APN Settings On An IPhone
click HERE
visit HERE
Changing APN Settings On Android Phones
click HERE
Good Luck
06-23-2021 06:50 PM
Make sure your cellular data in on and check you apn settings.
https://www.publicmobile.ca/en/bc/get-help/articles?q=Apn
