Data is not working
Ranjan1981
Since noon my Data is not working
Skimby14
I've had the same issue since yesterday. Didn't have any mobile data yesterday. It seems that many people in my area (BC/Van) have been having issues. I'd recommend anyone with an issue to make a ticket so they can investigate this
eddieO
@Ranjan1981, if you are using an Android phone something else to look for is to make sure you do not have any data limits set in the phone's settings, does not apply if you are using iPhone.
Meow
You might be out of data. Test your sim in another phone. PM might have issues. Check your account to confirm you DO have data available. I just checked and it data works just fine in GTA area.
