04-04-2019 09:34 AM - edited 01-05-2022 04:09 AM
If I choose a 90 day plan.. for example the a plan with 6 +1.5 Bonus GB/90 days does this mean I only get 7.5 GB for the enite 90 days or is it per month?
Thanks
04-04-2019 09:57 AM
When in doubt ask, and save the headaches. @vpopo when building your own plan for 90 day, the data portion says...6 + 1.5 GB Bonus at 3G Speed/90 days. That is 7.5 GB 'per' 90 days.
04-04-2019 09:56 AM
As mentioned it's 7.5 gb over the 90 days or 2.5 per 30 days. The benefit of the 90 days is that you can spread your usage so if in month 1 you use 4 gb instead of 2.5 you have 3.5 over the next 60 days.
04-04-2019 09:52 AM
@vpopo wrote:If I choose a 90 day plan.. for example the a plan with 6 +1.5 Bonus GB/90 days does this mean I only get 7.5 GB for the enite 90 days or is it per month?
Thanks
It is not per month. It is spread out across the entire term. You could use it up in your first week or save it and cram some HD video at the end. Or just be sensible with your data consumption.
04-04-2019 09:44 AM
Thanks
I believe it would be for the 90 days.
04-04-2019 09:44 AM
You only get 7.5 GB for the enite 90 days
