Data did not reset with new plan cycle
Saucisse
Hello
My plan usage shows a
1024.00 MB used
but it just renewed July 15. Who can take a look ar it?
thanks
9 REPLIES 9
@Saucisse
usage the direct message method to open ticket with PM CS agent
And, did you check the usage log? filter by Data and check if shows you really used 1GB since July 15
popping
@Saucisse
Clear your browser cache and start your browser in private mode and try again.  OR use another browser.
If you are still have issue creating ticket, you can send a private message to CS Agent. The response time will be slower without a trouble ticket.  BTW, there 9 Agents online at the moment.  You will get a response within a few hours.
Your phone be accidently used more data as usual.  What is your usage history showing how much data you were using for the last couple of days?
@Saucisse
If ticketing not working,
Send a private message to moderator through the following link :
CSA may ask a few questions to verify account ownership and then should be able to help you. Response times can take a few hours.  Check your private message inbox (envelope in upper right corner of website).
Saucisse
Tried submitting a ticket again and not working. Now what?
Saucisse
Cannot submit the ticket…
popping
@Saucisse wrote:
Hello
1024.00 MB used
thanks
If your renewal date is July 15, your plan will be reset at 12:00AM ET.  If you live in BC, your account will be reset at July 14, 9PM PT.
Check your usage history since July 15.
If you are certain that your data was not reset, create a trouble ticket using the Chatbot(SIMon) link at the bottom of this page.
@Saucisse hi looks like it’s all used up
Do you have Wi-Fi assist enable do you leave your data on all the time ,might be updates we’re done
Saucisse
Hi
it is plan usage. Used max 100mo according to my history. Will open a ticket
HI @Saucisse   were you checking those usage for Plan Usage or Add-on Usage?
Those on Plan usage would be your regular monthly usage, not those on Add-on Usage
(Add-on Usage are for the bonus add-on and the extra add-on you purchased)
Please provide a screenshot
but if you confirmed you checked the right one, open ticket with CS agent for help:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
start by typing : Contact CS Agent
then Click "Contact Us"
then Click "Other"
finally Click "Click here to submit a ticket"
