Data add on
Mike231
Hi- why when i add data, it will not show right away on my account? Is there any number to call at PM to fix the issue right away? Ty
@Mike231  should be there as soon as it’s successfully purchased . check like this
Try again incognito/private mode
And or lap top /computer
                    OR
simply try refreshing the page to check data plan / mins / add ons
@Mike231 - once you purchase the addon and if you don't see it in your My Account right away, try calling 611 to check your data balance (this will include any plan or data remaining balances on your account). Does this tell you what you expect?
@Mike231 it could be just a browser cache problem
Please re-login My Account using Incognito mode and check if the addon shows up there.
Also check payment history and see if PM took the money and used the money to buy the data addon
https://myaccount.publicmobile.ca/en/account/payment/payment-history
Also, confirm your credit card to see if PM really took your money
If you see the addons on My Account, reboot the phone and try using data again
If you are on Android, make sure you disable your Data limiter on the phone
