Phone not activated
Heaven2311
I changed to one of the new plans offered this moth, the 39$ plan, I can receive and send texts, and receive phone calls, but when I try to make a call I get a recording saying my phone is not activated on the network……anyone know what might be happening?
10 REPLIES 10
@Heaven2311 wrote:
One week in and still can’t make a call, how do I contact support?
@Heaven2311 Ways to contact Public customer support below:
1-Normally Faster - use this link to: Get Help With Public Mobile Chatbot], also found in various places in Public webpages, OR
2-go to your envelope at the top right of your Community Account which is where your Inbox and Sent messages are. Select the orange/peach color box with the pencil inside it to start a new message. Type CS_Agent in the SEND TO box. This will create a private message to Public Mobile Customer Support (link is provided in #3 below as well).
3 -Use this link (same as #2 as well as provided by @dust2dust above)  Private Message to Public Mobile Customer Support Agents (CSA)
Heaven2311
Heaven2311
Yes, I have reset the network settings a couple of times,
@Heaven2311 - have you tried to perform a Reset of your device's Network Settings, if not see if this helps. This also resets Wi-Fi networks and passwords, cellular settings, VPN and APN settings, and connected Bluetooth devices that you've used before.
Iphone: To Reset Network Settings, begin by opening the Settings app. Next, tap General -> Transfer or Reset iPhone -> Reset -> Reset Network Settings. and enter your passcode. Your iPhone will reset network settings and restart itself.
android: Find and tap Settings > System > Advanced > Reset options > Reset network settings.
EDIT: Although this sounds network or account related, try removing your SIM and try it in another phone. Do outgoing calls work? Either way, move the SIM back into your phone and then test. Sometimes the act of trying into another device may reset something in the backend.
Heaven2311
Yes, it give a code first …..7B1
Is it giving you a code at first on that recording?
Adding- I think you'll need support to 'refresh' your service.
Heaven2311
I just did that and keep getting the message that my phone is not activated on the network.
Can you try setting the network to 3G or WCDMA.
Heaven2311
I’ve tried that several times
dust2dust
Might it take a simple power off restart.
