07-24-2019 01:42 PM - edited 01-05-2022 06:04 AM
07-24-2019 02:28 PM
Did you maybe set limits for the usage on your phone?
07-24-2019 01:50 PM
@an739729 wrote:Hi there
I purchased a data add on of 1 GB for $30 after I had used my data amount for the month. I see it listed under purchases on my account but when I try to use that data my phone says no connection. Can you help?
Purchasing addons is a two step process. Here is a great tutorial on how to purchase addons created by @srlawren https://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/HOWTO-Purchasing-Add-ons/m-p/198974
07-24-2019 01:49 PM
PS if your cellular data is turned on and it still shows no network connection, go into your phone settings/cellular data/ cellular network settings and make sure under ACCESS POINT NAMES "public mobile" is selected and it should state sp.mb.com (at least that is what is shows on my phone). You can also check under "available networks" and click Public Mobile here too. When you have cellular data turned on, there should be a different icon on your phone than the usual wifi icon on top of the phone.
07-24-2019 01:48 PM
Make sure it is a two step process for add-ons. You need to add and then purchase it.
To purchase Add-Ons using your Self-Serve account, follow these steps:
When you log into your self serve account under data and add-ons there should be amount showing. Also make sure you enable data.
07-24-2019 01:45 PM
Depending on what phone you have, go into your phone settings and turn on cellular data. It is probably turned off my default. On my phone I click settings, data usage, telus and under cellular data there is a button to switch on. Hope that helps!
07-24-2019 01:44 PM
Try turning phone off / on.
