03-09-2022 10:00 AM
How to tell how much data you have left on plan for the month?
Thanks,
Chris76
My Account
03-09-2022 12:13 PM - edited 03-09-2022 12:14 PM
If you don't see your plan data counter on your overview page then you have used it all up. You will recieve a text message from 611 at 75% and 95% usage of all data** on your account.
**Plan and any bonus or add on data.
Edit:
Above in bold.
03-09-2022 11:39 AM
@Chris76 -
I cannot offer any more better advice than what the others have posted, as those screenshots are the most accurate of data usages on your plan.
If you never created a self serve account, register for one here: https://selfserve.publicmobile.ca/self-registration/
Strangely, you can review all your Minute and Data ADDONS when calling 611 from your device (using your 4 digit Account PIN).
But, for regular plan Minute and Data usage, it does not tell you. Wish this was an option for this in 611. 🙄
03-09-2022 11:14 AM
Just log in to your account and you will see it right away:
03-09-2022 10:08 AM - edited 03-09-2022 10:09 AM
@Chris76 Just login to My Account. There is a section My Data & Add-ons, it would show you a line of the data and it will show how much allocated and how much you used, like the line below about 250 MB at 3G speed, in this case 33MB used out of 250Mb. If you don't see such line, that mean all your data all used up:
