Data Usage Riddle
x409
Hello, riddle me ree: how much data have I used in my current billing cycle? I have attached 2 different conflicting images showing plan usage from what I think is the same billing period. (Does add-on data get used before regular data?) Thanks!
8 REPLIES 8
No worry @hairbag1    🙂
We are happy as long as OP got helped
@x409...
with use of visual aids..I think @hTideGnow  was able to give you a clearer idea of what's going on and answer your question better.
If it was up to me...I'd award the SOLUTION to him. You can still do that.
x409
Thank you!
x409
Thanks!
x409
Thanks hTideGnow !
MrSpock
@x409hi it's no riddle, you used all your one time bonus given to you and you used 81% of a 1 gig add on you purchased 😀 your current cycle you have 812 mb left
hairbag1
You've used up 211.3 MB's of regular plan data.
Sometime in the past you bought a couple of data add-ons. One is fully consumed and the second has 198.8MBs remaining for use if you run outta regular plan data.
@x409 wrote:
HI @x409   the above is for your current cycle , used up 211.30 out of 1GB
@x409 wrote:
the other screenshot is for your extra , non expiring add-on. you used up 2GB holiday bonus already .. then another 1GB bonus, you used up 81% of that
(modified post to add OP's original images back)
