09-16-2022 03:42 PM - last edited on 09-16-2022 05:00 PM by computergeek541
Since last night the cellular data on my iPhone 8 has stopped working. I was on a $40 5gb plan and switched to a 1gb 25$ plan, which was successfully paid for last night. So far I have tried updating my phone to 15.7, changing my apn and even completing a network reset. I'm still able to use my SMS and call functions. Any help would be greatly appreciated! Thanks
09-16-2022 03:58 PM
@hTideGnow- Everything here belongs to the company. To give credit is always nice but a modification makes it theirs.
09-16-2022 03:54 PM - edited 09-16-2022 03:55 PM
@dust2dust wrote:@hTideFnow- So you're quite new here.
just this latest account is quite new
and how hard to write something of your own ? she needs to "modify" from the Best ?
09-16-2022 03:50 PM
@hTideFnow- So you're quite new here. Let alone saying the same thing well after somebody has already said it, but the customer chose a solution already (very quickly) before you posted. Not really necessary to say the same thing as the chosen solution.
09-16-2022 03:47 PM
open a ticket with PM CS_Agent. at : https://publicmobile.ca/chatbot.
type: Contact Us and Other
Finally Click here to submit a ticket
If you have error submitting a ticket, send a private message to the CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
check inbox(top right corner envelope icon) for response
09-16-2022 03:44 PM
There's currently a trend of people losing service after changing their plan. But you seem to be getting some service. Are you sure texting isn't through imessage and on wifi? SMS would be standard cell. And may not work. But your calling, is that both in and out?
09-16-2022 03:43 PM - edited 09-16-2022 03:44 PM
HI @jojo861 many people with plan change on renewal has problem since yesterday. Please open ticket with CS agent:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
start by typing : Contact CS Agent
then Click "Contact Us"
then Click "Other"
finally Click "Click here to submit a ticket"
