Data Roaming in Canada
Luddite
Is Data Add On Canada wide even if I only have the Provincial Talk plan? Looked but can't find it.
9 REPLIES 9
srlawren
@bostik wrote:
Does this include calling within another destination city within Canada? For example if I travel from Vancouver to Toronto. Will all my calls within Toronto be consider local calls or will I need to purchase another add on?
@bostik it depends if your plan includes Province-wide talk or Canada-wide talk.  Please see here for all the details:  https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Plans-amp-Add-Ons/ta-p/250167
@bostik wrote:
So there is no data roaming charges if you travel across Canada as long as your plan has data?
All Public Mobile services work anywhere in Canada (in range). All talk plans cover outbound calls. People calling you need to be aware of their own calling plans. Province-wide plans are little trickier.
Your data will work anywhere in Canada as long is your plan is active.
bostik
Martin
Legend
Legend
Luddite,
You're quite welcome!
Thank you all for providing the info I wanted. 🙂
Hi. @Luddite, Data is Truly 110% Canada-Wide and available.
Now, if PM can open the front door to even more.
The process is still evolving
Martin
Legend
Legend
Hello,
Regardless of your talk plan, a data add-on will function in any location in Canada where there is PM/Koodo/Telus coverage.
I hope that this has answered your question.
chukdefatey
^Correct
